Activity Forums VEGAS Pro XDCAM clips
  • XDCAM clips
    Posted by Thomas Quinn on October 11, 2006 at 10:07 pm
    Hope this dosent sound like a daft question but here goes when I transfer MXF files from my 330 camcorder I just drag clip to my hard drive this is ok when using one disc but if I copy two discs and try to renumber the MXF files all the clips with single numbers 1-2-3-4 ect are not appearing where they should and things get confused. anyone help here (I am using Vegas 6)
    Thomas
    Dr. Dropout replied 19 years, 11 months ago 2 Members · 1 Reply
  • Dr. Dropout
    October 12, 2006 at 1:13 am
    Vegas 6 has file reading support for SD XDCAM MXF files only- works ok within that set of constraints. If you want to continue using Vegas 6 you’ll have to come up with your own file management scheme to deal with similar clip names (copy to unique folder or rename…or something similar)
    Vegas 7 (there’s a free fully-enabled 30-day trial) has an XDCAM viewer pane, proxy editing support, proxy conform, multichannel audio support, hi-performance HD support, master to disc support and a lot more. No problem with file naming- import the disc inside Vegas 7 and all is handled.
    If you have invested in XDCAM hardware, Vegas 7 is definitely worth a close inspection. In addition to Sony marketing materials and app docs, here’s a 3rd party website that provides a good overview:
    https://www.simonwyndham.co.uk/Vegas7.htm
