Activity Forums Apple Final Cut Pro Legacy XDCAM and P2 software
  • XDCAM and P2 software
    Posted by Justine-paula Robilliard on June 9, 2011 at 4:08 pm
    Hi All
    I love the COW, I am at present trying to set up my apple laptop to work as a freelance video editor, and I would like to find out what software I would need to install to use devices such as XDCAM and P2, as this is what the broadcaster here uses, and I am a freelancer there, mainly doing the audio side, but I have told them I have FCP and I just need to know what versions of XDCAM and P2 software drivers updates I would need to install in order to work with the camera’s and disks.
    Thanks so much..
    Justine-Paula
    Andrew Rendell replied 15 years, 2 months ago 3 Members · 2 Replies
  • Shane Ross
    June 9, 2011 at 5:11 pm
    First off, here is the tapeless workflow for FCP. You must know this…
    Tapeless Workflow for FCP 7 Tutorial
    I have links on there for P2 drivers and software and XDCAM software and drivers. XDCAM can be imported via FCP’s log and transfer like I talk about in the tutorial, or via external Sony software called the Clip Browser.
    Shane
  • Andrew Rendell
    June 12, 2011 at 8:59 am
    The only thing I’d add to Shane’s post is that Sony also have a driver/utility for you to read their SxS cards in your Expresscard34 slot.
