Activity Forums Adobe After Effects xdcam 50fps import to fcp sound sync problems
  • xdcam 50fps import to fcp sound sync problems
    Posted by Rich Tru on April 24, 2011 at 9:11 am
    HI
    I shot on canon f35 on CF cards – In XDCAM transfer I see all my shots running on the timeline in sync, everything is perfect 50/mbs and 50fps. When I send to FCP 7 and drag the clip onto the timeline and play – the clip is completely out of sync and scratchy . Also I have tried every codec setting to change the fps, I need the settings to be 50i and not 25p as I see 25p under the vid rate column and I think this is throwing it out of sync . I need the correct and best quality preset and capture settings at 50i on FCP7 and also someone to help fix my problem with sync.
    Tudor “ted” jelescu replied 15 years, 4 months ago 2 Members · 1 Reply
