Activity Forums Sony Cameras XDCAM 350 & EX1 working together
  • XDCAM 350 & EX1 working together
    Posted by Kc Allen on July 27, 2009 at 2:40 am
    Sometimes when I use the footage from my cameras in the same timeline, the footage from the EX1 appears to be strobing. It doesn’t always do it, but it happens 75% of the time. Both are filming using the same settings, normally 1080P, but not in HQ mode. In my FCP timeline, I’ve tried setting the compressor to PreRez, HDV and various other settings, and there’s no change. Any ideas?
    KC Allen
    Allen Film & Video
    “My name is actually spelled KC…really…it is…”
    Andy Mees replied 17 years, 1 month ago 3 Members · 3 Replies
  • Noah Kadner
    July 27, 2009 at 2:52 am
    Strobing is a vague term- can you be more specific? Strobing during a pan, literally flashing frames, etc?
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
    Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
    https://www.callboxlive.com
  • Kc Allen
    August 8, 2009 at 2:56 am
    Tough to describe. The footage is jerky, particularly during movement like jib/dolly or handheld movements, but it can even look a little uneven when locked down, although it’s tougher to notice it.
    KC Allen
    Allen Film & Video
  • Andy Mees
    August 9, 2009 at 2:43 am
    Kasey
    It sounds for all the world like the symptoms of field order mismatch. Find an instance of when this is happening and then post back with the clip properties reported by FCP for the flickering footage, plus the sequence properties for the sequence where you are seeing it.
    For clip properties, select the flickering clip in the timeline and choose Cmd-9
    For sequence properties, select the timeline window and choose Cmd-0 <-- that's a zero by the way 🙂 Also please select one of the clips in the same sequence that is not displaying this flicker, and post back with thart clip's properties too. Best Andy
