Activity Forums Sony Cameras XDCAM 2.9.0 Update – incomplete package??
  • XDCAM 2.9.0 Update – incomplete package??
    Posted by Ray Raley on March 5, 2009 at 2:44 pm
    I have installed the PDZK-P1(V2.90).zip software package on three systems so far. The new U1 utility installs and I have upgraded the firmware on three U1s. I can now change disc names and write to the General subdirectory.
    However, there was not an installer for XDCAM Transfer in the .zip package. After the update the version is still 2.8. I cannot export a sequence as a clip to the U1. I can export a MXF to the General subdirectory.
    For those who have upgraded, what is your experience? Thanks!
    Justin Gaar replied 17 years, 6 months ago 8 Members · 9 Replies
  • 9 Replies
  • Olof Ekbergh
    March 5, 2009 at 5:24 pm
    Make sure you installed all the updates and drivers on this link:
    https://www.sony.co.uk/biz/view/ShowSiteSection.action?sectiontype=BC%20Tools%20XDCAM&site=biz_en_GB
    Olof Ekbergh
  • Ray Raley
    March 5, 2009 at 6:05 pm
    Thanks, but USA customers are not allowed to register. I used the software provided at the US Sony Services Plus website.
  • Craig Seeman
    March 5, 2009 at 6:23 pm
    USA Sony site is missing the actual XDCAM Transfer Tool 2.9 software. The installer only has the drivers. I had no problem ensuring that Brooklyn is part of the UK though.
    After all the British did force George Washington to retreat off of Brooklyn in late August, 1776.
  • Don Greening
    March 5, 2009 at 6:54 pm
    Looks like the Canadian site has it if you’re looking for XDCAM Transfer Tool v.2.9.
    https://www.sony.ca/xdcamex/support.htm
    – Don
  • Ray Raley
    March 5, 2009 at 7:58 pm
    After a clever registration, I downloaded the dmg missing from the US. We finally wrote a FCP sequence to the U1’s clip folder via USB. Finally, round trip from XDCAM HD camcorders! We have two 700s and a 355.
    Thanks for all the guidance. Ray
  • Rafael Amador
    March 6, 2009 at 5:03 am
    Yesterday I was complaining that the Canadians were to slow this time.
    No way to download from the UK.
    The country I live in is don’t even exist for them.
    Canada won once again:-)
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Brian Volland
    March 9, 2009 at 6:56 pm
    Finally the update is here. So let me be the first to ask a question. Can I mix formats when exporting from FCP? I sent two 1440×1080 XDCAM HD 1080i60 VBR files and they copied over no problem. I then tried to export a 1920×1080 XDCAM EX 1080i60 vbr but got the following error message:
    Please check that your XDCAM device is set up correctly, the REC INHIBIT indicator is off, and the disc is not full.
    The device should be configured like this:
    Video: MPEG HD 60i. Audio: 2 ch x 16 bit
    Error writing MXF file (while checking successful write()).
    I have over 50% open disc space, audio configured to 4 channel, dual mono. Only thing I can figure is that I can’t export different formats. Am I correct?
  • Ryan Gillentine
    March 11, 2009 at 2:53 pm
    Brian, I am having the same problem. Write is enabled, but I can’t tell why the media won’t write to the disc. Anyone have any thoughts?
  • Justin Gaar
    March 11, 2009 at 8:51 pm
    i could be wrong, but i believe the largest you can write back to disc, currently, is 1440×1080. It should, however, transcode your EX footage to 1440×1080. But you cannot then go back to 1920×1080 without quality loss. that is what i’ve come to understand from a Sony ICE Team member.
