Activity › Forums › Apple Final Cut Pro Legacy › XDCAM
Posted by Daphne Gomez-mena on August 27, 2007 at 8:51 pm
Does anyone know how an upload to hi rez is done on final cut pro with the XDCAM? can you batch capture as you usually would or is that not possible with the XDCAM software?
i.e. can you treat the xdcam as a regular deck though log and capture??
John Pale replied 19 years, 1 month ago 4 Members · 10 Replies -
John Pale
August 27, 2007 at 8:58 pmFCP only works with the hi res video. It does not work with the proxy footage at all.
You can browse the proxies with the Sony software, but you edit with the hi res clips. -
Mark Maness
August 27, 2007 at 9:17 pmThat mostly true…
You can edit with the proxies but it will take considerable time to make them using the Sony Transfer software.
So to answer the original question… Yes, to both.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
John Pale
August 27, 2007 at 9:20 pm[Wayne Carey] “You can edit with the proxies but it will take considerable time to make them using the Sony Transfer software.”
Yeah. I had a sit down with Sony recently, and the rep cringed when the subject came up. It can be made to work, but I would not try it on anything but a short spot.
Mark Maness
August 27, 2007 at 9:31 pmVery true!
Some people just insist on edit proxies first.
Wayne Carey
Schazam Productions
Chris Borjis
August 27, 2007 at 9:46 pmwasn’t that the entire point of XDCam?
To get going editing right after recording, before you made
it back to the tv station for the news? -
Daphne Gomez-mena
August 28, 2007 at 11:48 amperhaps i didn’t explain myself correctly.
I am working with low rez footage that someone else digitized and want to make my low rez project – hi rez when it is final,
is that possible through the batch capture method though the log and capture function of final cut pro?
so to clarify am not talking about working with proxies at all…
thank you
Mark Maness
August 28, 2007 at 1:52 pm[dgomezmena] “is that possible through the batch capture method though the log and capture function of final cut pro?”
Yes…
As long as the footage reel names are correct and labeled properly, you shouldn’t have any issues uprezzing the way you want.
Wayne Carey
Schazam Productions
Daphne Gomez-mena
August 28, 2007 at 2:37 pmhow do i do that? in the audio settings for the capture preset and the device control preset there is no option to select the XDCAM camera as a deck or the media as XDCAM… only Sony HDV firewire, which i tried but it is not recognizing the camera…
is there a way to batch capture through the XDCAM sofware???
thank you
daphne -
Chris Borjis
August 28, 2007 at 11:27 pmno there is not I believe.
If you do it through firewire or ethernet you have to install this software and “copy” the files over.
You will need to digitize over SDI if you want to batch capture it for online.
