xd5b file
Posted by Frank Stevn on March 13, 2014 at 10:00 pmCan’t open this MOV file in Vegas pro 12 (only see audio tracks). The same in Quicktime, only audio. Only VLC can play it.
Fotmat: xd5b, 1920×1080, Millions 24-bit Integer (Litle Endian), 4 Channels 48.000 kHz
Any suggestions?
Steve Rhoden replied 12 years, 6 months ago 3 Members · 7 Replies -
Steve Rhoden
March 14, 2014 at 12:18 amWhere/What you got it from?
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Frank Stevn
March 14, 2014 at 12:50 amFrom a TV studio.
The editor tells me he uses Premiere to edit the files, and he can open them in Quicktime.
I have Premiere and QuictimePro and neither of them can open the file.
Norman Black
March 14, 2014 at 4:31 amI believe you need the Quicktime MPEG-2 component installed for that.
I found it here. It is not free, so you will want to make sure this will give you what you want somehow. Or convert it with some utility that handles the file.
https://store.apple.com/us/product/D2189Z/A/quicktime-mpeg-2-playback-component-for-windows
Steve Rhoden
March 14, 2014 at 10:23 amOr Calibrated Software Codecs https://www.calibratedsoftware.com/
Which is also not free.Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Frank Stevn
March 14, 2014 at 4:05 pmThanks Norman and Steve.
I installed Calibrated{Q} XD Decode, Quicktime can play the files and I can edit the files in Vegas 12.
Norman Black
March 14, 2014 at 6:43 pmYou can probably also use Avidemux, or similar, to simply remux the files into an MP4 or MXF file format and Vegas could read that directly with its own internal decoders. Vegas supports XDCAM EX in the MP4 format.
Steve Rhoden
March 14, 2014 at 9:24 pmGood!
Steve Rhoden
(Cow Leader)
1-876-461-9019
