Activity › Forums › Apple Final Cut Pro Legacy › XD, HDV, DV – Best Sequence Setting?
  • XD, HDV, DV – Best Sequence Setting?
    Posted by Erik Nolder on May 14, 2008 at 11:42 pm
    Have a Dual G5 with FCP6…and editing a long format SD project with a mix of footage – XD/HDV in HD and DV/DVCam is SD. Should I use a ProRes SD sequence setting or XDCam HD? But I’m thinking editing in HD, even with the low bit rate of XD will still punish my system..any thoughts?
    Shane Ross replied 18 years, 4 months ago 3 Members · 4 Replies
  • Shane Ross
    May 14, 2008 at 11:47 pm
    If your project will be an SD project, then just edit everything in SD. Capture your HDV as DV…your camera and deck can output it as such. Make your life easy.
    What is XD?
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Erik Nolder
    May 15, 2008 at 12:12 am
    It’s Sony’s XDCam…HD, but at a bit rate fairly close to DV…and unfortunately most of it and the HDV is already digitized as HD on drives. I’m thinking the best sequence setting would be the NTSC ProRes in 16:9…however, everytime I put a XDCam clip on it, the red render bar appears…one option I haven’t explored would be an XDCam sequence setting in SD…if one exists…thanks, E
  • Andrew Kimery
    May 15, 2008 at 12:27 am
    If you create an HDV or XDCAM HD sequence (I’d go w/which ever format you have more of) and go to the Sequence settings, under the “render control” tab you can set the sequence to render in ProRes. This will keep any effects or color correction you do in the ProRes codec.
    -A
  • Shane Ross
    May 15, 2008 at 12:38 am
    If you drop an HD clip onto an SD timeline, it will require rendering of some sort…but you should be able to do this without the RED render bar.
    Is most of your footage HD or SD? If HD, then edit in SD, upconverting the SD footage. And Andrew has your back, set the render control to ProRes so when you render, it will be ProRes. ProRes HD. To get it back down to SD you should get an HD capture card.
    Shane
    http://www.LFHD.net
    Read my blog!
