Activity Forums Apple Final Cut Pro Legacy XD CAM transfer problems
  • XD CAM transfer problems
    Posted by Steve Cain on June 20, 2009 at 12:46 am
    This is my first attempt with Sony XDCam footage, and there are 2 problems. When attempting to import clips in FCP using the transfer app, the transfer window opens, but after about 10 seconds FCP crashes. I have updated the transfer app, trashed preferences, used default preferences in the transfer app while disconnecting external drives and it still crashes. Finally, I have opened the transfer app only and imported all the clips, then imported those clips into FCP. Seems to work fine — except, and this is problem #2. All clips, when played in FCP look fine. When played in QT player, whether original QTclips (created by transfer app) or exported from FCP, have aliasing on any moving vertical line (pedestrians, moving vehicles, camera pans, etc. All motion is blurry.
    XDCAM EX 1080i50 35 MB/s VBR 1920×1080
    sequence is in native codec, but I tried changing a copy to PRORES 422, exported as QT both sequences, using PRORES 422; again in native codec, but it always looks the same.
    PowerPC G5 dual 2.3 ghz,
    3G ram
    FCP 6.0.5
    Raid 5 external drive thru eSata connection 3132
    Thanks for any help
    Steve
    Steve Cain replied 17 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    June 20, 2009 at 1:17 am
    The shabby look in quicktime player is probably because in preferences you haven’t selected “use high quality video settings..”
  • Steve Cain
    June 22, 2009 at 1:12 pm
    Michael,
    Thanks for your help, but while that box wasn’t checked, it made no difference. Any other thoughts? Is there something in the transfer program I’m overlooking?
