Activity Forums Apple Final Cut Pro Legacy XD CAM Transfer problems
  • XD CAM Transfer problems
    Posted by Carlton Hathcoat on September 13, 2011 at 4:45 am
    I am using XDCAM for the first time (Usually use P2) and the Video was shot 1080i60 (50Mb/s). I used the XD Cam Transfer and everything seemed fine, but I have noticed in FCP that the Frame Rate is 29.97, not 59.94. Anyone know what’s up? Also, the video has some aliasing? Is there something I can do for that? The footage was shot in Drop Frame.
    Sam Cole replied 15 years ago 3 Members · 2 Replies
  • Bouke Vahl
    September 13, 2011 at 10:31 am
    Make a study about ‘interlace’
    (and yes, that will set you back a couple of days before you understood everything. Short story, your material is fine, you are in for a lot of problems unless you catch up with modern technologie. And with that i mean technology that goes back some 80 years.)
    Start here:
    https://en.wikipedia.org/wiki/Interlaced_video
    And don’t post any questions before you have read it all.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Sam Cole
    September 14, 2011 at 12:10 am
    [carlton hathcoat] “I have noticed in FCP that the Frame Rate is 29.97, not 59.94. “
    Bouke is pointing you to a good start but just to help you get there, 59.94 is a number representing ‘fields’. There are 2 fields per frame so that equates to . . . yep, you guessed it; 29.97 frames.
    Don’t get confused with camera’s that can shoot ‘off speed’ eg 60 FRAMES per second.
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
