Activity Forums AJA Video Systems XD Cam and Kona
  • XD Cam and Kona
    Posted by Michael Allen on August 7, 2006 at 1:26 pm
    I am contemplating the new Sony PDWF330 XDCAM HD. I have a Kona LH and FCP 5.0.4. Until I upgrade FCP, (which should give XDCAM support) I am planning to go directly to DVCPro100HD through the component inputs. My question is, will this yeild good results or should I upgrade FCP immediatly.
    My thought process was to skip the intra frame (HDV like) codec and move directly to a better codec like DVCPro100HD. Is this a good plan? I have no way to test so I could use a little help from anyone with experience.
    Mike
    Mark Maness replied 20 years, 1 month ago 4 Members · 3 Replies
  • Arnie Schlissel
    August 7, 2006 at 3:46 pm
    The upgrade is only $49.00. Why wait?
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
  • David Slater
    August 7, 2006 at 11:19 pm
    I would do the upgrade but do what you were thinking with using DVCPRO HD as you can’t use the 35 mb/s signal (natively) which is the only way you should be using XDcam (kidding . . . . sorta).
    I am doing XDCAM HD with FCP 5.1 using my LHe
    captured it all over SDi
    DAVE at Movies Rock in Toronto
  • Mark Maness
    August 22, 2006 at 3:40 pm
    I’m using a Kona 2 to capture my XD HD using DVCPRO HD and it looks absolutely stunning!
    But let me ask… Are you looking at the F330 for budget reasons? If you can find a way to swing it, the F350 is a better camera since it can overcrank and undercrank your video and the ability of having an HD-SDI output is a major feature for us.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
