Activity › Forums › Maxon Cinema 4D › XBreaker on Extrude Nurbs
Posted by David Biederbeck on February 28, 2011 at 10:27 pmCan anyone explain to me how to apply the xbreaker script to a spline created in Illi, which is currently in an extrude Nurbs?
Thanks.
11.5
David Biederbeck replied 15 years, 6 months ago 2 Members · 4 Replies -
Michael Szalapski
March 1, 2011 at 3:35 pmHow about making your object editable first?
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
David Biederbeck
March 1, 2011 at 4:06 pmI have tried that, by pushing C, which creates a null, with each individual spline within an extrude nurb beneath it.
Then I used the xbreaker script both on the null, and on the individual splines and it still did not work.
Michael Szalapski
March 1, 2011 at 4:11 pmYou have to carry on down and make all of those editable too. Do that until you’re left with only actual polygon objects. Then you’ll probably want to use the connect and delete function so that it’s all one piece. Then run XBreaker on that.
– The Great Szalam
