Activity › Forums › Avid Media Composer › XAVC MC7 ama link/import problems
  • XAVC MC7 ama link/import problems
    Posted by Bj Emery on September 19, 2015 at 3:02 am
    I have several MP4’s that were shot on a Sony a7s.
    XAVC/120fps
    I have downloaded and installed the XAVC/XDCAM Plug-in for Avid (PDZK-MA2) v 3.41.
    I am still unable to ama link to the footage, it just tells me it is unable to link.
    I checked the console and it says that these are installed, I assume the second one is the one I recently installed because of the same version number.
    MVP_MSP_SonyXDCAMEX_64bit Sony Corporation 1.9100
    MVP_MSP_SonyXDCAM_64-bit Sony Corporation 3.4100
    Is there anything I am missing? I am beating my head against a wall here, and would love to find an open window.
    Bj Emery replied 11 years ago 3 Members · 5 Replies
  • Massimo Alberto croce
    September 19, 2015 at 9:19 am
    instead of auto-detect plug in in the link to ama dialog box, try to use Sony plug in.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Michael Phillips
    September 19, 2015 at 12:08 pm
    If it is recorded using the XAVC-S codec, then it is not supported by the Sony AMA plug-ins. There has been lots of threads on this issue. For example: https://community.avid.com/forums/t/129982.aspx?PageIndex=1
    You can use Resolve to transcode, ClipToolz to rewrap (PC), purchase an AMA plug-in from Drastic Technologies that supports it ($99), and some other workarounds that I may be missing but others can fill in with here.
    Michael
  • Bj Emery
    September 19, 2015 at 4:45 pm
    I tried that, thanks for the suggestion! It still didn’t work though.
  • Michael Phillips
    September 19, 2015 at 5:07 pm
    Which solution and what didn’t work exactly?
    Michael
  • Bj Emery
    September 20, 2015 at 8:51 am
    I’m sorry. I tried selecting the sony plugin manually as Massimo suggested and it still didn’t work.
    I also have tried “wrap to MOV” in cliptoolz as I saw suggested in another thread, no dice.
    I guess I will have to transcode through resolve.
