Activity › Forums › Apple Final Cut Pro Legacy › XAVC into final cut 6.6
  • XAVC into final cut 6.6
    Posted by Ricky Barnes on July 11, 2018 at 9:56 pm
    Hi:
    Ok – I know. FCP 6.6? I’m always on the cheap… But I do freelance DP with my fs7, and on occasion edit with my somewhat antiquated platform.
    So I currently use Aunsoft to transcode the MX files to quicktime files, so I can thereby input to my Studebaker editing program. Am I losing quality? The Aunsoft website says it’s lossless. But I’m not convinced. I have done some of this, and it generally looks pretty daggone good, but of course I haven’t done a cross-comparison (except with the footage from my AF-100 and I don’t notice anything). But I’m looking for a “tech-spec” guru who can alleviate my suspicions and say “It’s all good, bro” – or “Dude – you need to upgrade to FCP 10ish”.
    Thanks for your support.
    Truly,
    Rick
    Detour Pictures, Bozeman Mt (formerly of Seattle)
    Shane Ross replied 8 years, 2 months ago 2 Members · 3 Replies
  • Shane Ross
    July 12, 2018 at 12:00 am
    [Ricky Barnes] “Am I losing quality? The Aunsoft website says it’s lossless. But I’m not convinced.”
    Any time you convert from one format to another, you’ll lose quality. But, WHAT CODEC are you converting to? Some, like the one FCP prefers, ProRes 422, (HQ is there, but not sure it’s FCP 6 compatible)…you’ll get an image that, while compressed, and recompressing the image, virtually lossless. You won’t be able to tell the difference.
    [Ricky Barnes] ” But I’m not convinced. I have done some of this, and it generally looks pretty daggone good, but of course I haven’t done a cross-comparison”
    Here’s how you compare…. Drop a ProRes clip onto the timeline. Drop a native XAVC onto the timeline…put a DIFFERENCE MATTE on the top layer…if you see only black, that means it’s lossless…if you see some speckles, that means there’s slight difference. But, you can’t…as FCP doesn’t bring in the XAVC native. But, trust me, it’s virtually lossless…and actually put in a better color space. proRes is 10-bit, XAVC is 8-bit.
    [Ricky Barnes] “But I’m looking for a “tech-spec” guru who can alleviate my suspicions and say “It’s all good, bro” – or “Dude – you need to upgrade to FCP 10ish”.”
    Dude, you really need to update your editing software to something more current, so you don’t need to convert AT ALL. FCX…fine, if you can deal with that interface, it’s great. Premiere Pro…sure, but you can only rent it forever, not own. But, it’s not expensive, and deals with this native. Resolve…FREE…and can convert to pretty much any editing codec if needed, and great for final color (Almost an industry standard). Avid…you are a camera guy, you don’t need to use Avid. But, with new software comes new hardware…so this won’t be cheap. I like shooting with my HVX-170 too, it’s great! But DVCPRO HD…8 bit, anamorphic…10 year old camera.
    Shane
    Little Frog Post
  • Ricky Barnes
    July 12, 2018 at 2:59 am
    Cool.
    Thank you Shane for the good insight (and some reminders, ie 8bit vs 10 bit). I did not know Resolve is free. I will check that out. I appreciate..!!
    Thanks again !!
    Truly,
    Rick
  • Shane Ross
    July 12, 2018 at 6:31 pm
    Resolve Free works on everything up to 4K. To work in 4K, you need to pay.
    Shane
    Little Frog Post
