Activity Forums Media 100 XAVC import
  • XAVC import
    Posted by Mark Mooney on October 24, 2013 at 2:12 am
    Hi everyone..
    I just purchased the Sony F5 . The codec is Xavc .. I know that media 100 will not import .. But I am converting to ProRes and then importing.. For some reason .. Media100 is importing as 1080i instead of 1080p I Mac shooting 29.97.. Any suggestions .. Or ideas.. Wish there was a way to go in XAVC..
    Mark
    Mark Mooney replied 12 years, 10 months ago 2 Members · 2 Replies
  • Floh Peters
    October 24, 2013 at 11:58 am
    [Mark Mooney] “But I am converting to ProRes and then importing.. “
    How are you converting into ProRes? In the ProRes codec, there is a flag for interlaced/progressive. So the software doing the conversion writes the files as ProRes interlaced, which gets read by Media 100. You should check the settings of your conversion software.
  • Mark Mooney
    October 27, 2013 at 2:47 am
    Thanks Floh ..
    Using a software called ideal share.. Seems to work fine .. But when I import ..it is 1080i. If I change the import settings in M_100 to use media standard .. It rendered the file to progressive .. But with blacks crushed and gamma down.
    The 1080i file plays fine and looks good on a 1080p timeline .. But is awkward workflow with the processor switching between interlaced and progressive between the bin and timeline each time..
    Need to find a way to convert the XVAC to ProRes that M100 will except 29.97p.
    Thanks for watching our back Floh!
    Mark
