Activity Forums Avid Media Composer xavc format from Sony CX900 into Media Composer 7.0.4
  • xavc format from Sony CX900 into Media Composer 7.0.4
    Posted by Dennis Freeman on August 12, 2014 at 3:53 pm
    Is there a codec available from Sony that will enable the import from the CX900 XAVCS into media composer in MXF format (DNxHD)?
    Michael Phillips replied 12 years ago 3 Members · 5 Replies
  • Michael Phillips
    August 12, 2014 at 9:54 pm
    Have you tried the Sony AMA Plug-in?
    Michael
  • Richard Boghosian
    August 22, 2014 at 12:23 pm
    Unaware of a new plugin from Sony. Have checked their site this week. And a search for XAVC-S doesn’t even show up. FWIW, the footage imports into Premiere CC without an issue.
    Richard Boghosian
    Bogh AV Productions
    AVID 7.03 MacPro late 2013 D-700 OS 10.9.2 32Gb ram BMD Ultra 4K BM Desktop 9.3.3
  • Michael Phillips
    August 22, 2014 at 1:01 pm
    XAVC-s seems to be more a branding thing than an actual new variant of the VAVC codec itself from what I can gather. If that is the case, then the XAVC AMA plug-in should support it just fine.
    So this would be the one to try:
    https://www.sonycreativesoftware.com/pdzk-ma2
    Importing is no longer a preferred method for many of these new camera formats as it takes longer, and lose metadata that the plug-in can parse.
    Michael
  • Richard Boghosian
    August 22, 2014 at 2:10 pm
    Not to belabor the point, but I have tried to use the AMA link for the XAVC-S file format for 4K, and it is not recognized by MC 7.03
    Richard Boghosian
    Bogh AV Productions
  • Michael Phillips
    August 22, 2014 at 2:30 pm
    So there could be a version mismatch between Sony’s support and the version of the plug-in for MC. Can you send me a small file sample to look at? I don’t have files that claim to be XAVC-S. If so, please send to michael[at]24p[dot]com
    Michael
