Activity › Forums › Sony Cameras › X70 Cannot Select A or B SD Card?
  • X70 Cannot Select A or B SD Card?
    Posted by Ray Sherman on November 19, 2016 at 7:29 pm
    Hi, I’ve running on v3.00 using 4K. For the first time owning the X70, I loaded both SD card slots. I have some video on slot A, with slot B being empty and freshly formated. My problem is when I use the SLOT SELECT button it doesn’t switch from A to B or B to A. The LCD shows both A & B only. Simply said, I can’t switch to use one or the other independently. Any ideas? Your help would be most appreciated. Thanks, Ray
    Ray Sherman replied 9 years, 10 months ago 1 Member · 1 Reply
  • Ray Sherman
    November 19, 2016 at 8:39 pm
    Ok….. I had the setting on “Simultaneous” recording instead of “Relay” recording. Made the change and all work as expected. Figured it out in the manual, go figure……. Somebody, slap me LOL.
