Activity Forums Apple Final Cut Pro Legacy x264 encoder component failing in Compressor 3.5.3 – Failed: Codec not installed
  • x264 encoder component failing in Compressor 3.5.3 – Failed: Codec not installed
    Posted by Eric Bowman on March 27, 2011 at 2:25 am
    I’m having issues with the h264 codec lightening video when I export with Compressor. From my reading, I seems the gamma is shifting a bit. I heard that the x264 component is a better codec and that it fixes the gamma issue so I thought I’d try it.
    SO, I downloaded the dmg, and placed the x264Encoder.component in the Library/Quicktime folder. I see the x264 option show up when I create a setting in Compressor so I assume it’s installed correctly.
    When I submit the job though, it “thinks” for a second and displays “Failed: Codec not installed”. I also tried placing this in the UserName/Library/QuickTime folder thinking it might be a path issue but that did not help.
    Finally, I tried using QT 7.6.6 and it exported fine using x264 codec. So why the heck is this not working in Compressor? Any tips?
    I’m using OS 10.6.6, QT 7.6.6 and Compressor 3.5.3 if that helps.
    Eric Bowman
    Eric Bowman replied 15 years, 5 months ago 2 Members · 2 Replies
  • Rafael Amador
    March 27, 2011 at 11:56 am
    That shouldn’t be that way.
    Why don’t you run “Compressor Repair”?
    rafael
    http://www.nagavideo.com
  • Eric Bowman
    March 27, 2011 at 7:04 pm
    I never knew about Compressor Repair until now. That TOTALLY fixed it. Thanks man!
    Eric Bowman
