Activity Forums Adobe After Effects x y expressions
  • x y expressions
    Posted by Criis Daw on November 10, 2005 at 2:08 pm
    Help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I am trying to get me head round expressions.
    How can i make the y position of a layer be affected by the slider variable of an audio amplitude layer without the x position being affected.
    Cheers if anyone can help me.
    Any one know any good books or tutorials on expressions ??
    thanks
    love to you all
    Mike Clasby replied 20 years, 10 months ago 3 Members · 5 Replies
  • Ryan Hill
    November 10, 2005 at 6:34 pm
    Okay. I’m afraid I don’t have AE infront of me right now, so I’m missing a lot of details, but…
    A position is represented as a list of two values.
    [x,y]
    So to access just the X value, you go postion[0] and for the y value, you use position[1].
    So, what you’ll want will look something like
    [thisComp.layer(“audiolayer”),value[1]]
    But like I said, I might have the syntax wrong, because I don’t have AE in front of me. It could be:
    (thisComp.layer(“audiolayer”),value[1])
    CHeck this while you’re at it:
    https://www.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=&page=/articles/bassett_doug/connections/index.html
  • Mike Clasby
    November 10, 2005 at 7:14 pm
    Pickwhip the layer’s position to the channel slider in the Audio Amplitude Layer, by Alt clicking the position stop watch (layer to be moved by the sound)
    then pickwhip that to the slider of the channel you want in the Audio Amplitude Layer. You get a position expression like this:
    temp = thisComp.layer(“Audio Amplitude”).effect(“Left Channel”)(“Slider”);
    [temp, temp]
    Change the bottom line to:
    value + [0,temp,0]
    This is from an earlier post:
    Date: Aug 11, 2004 at 9:07 am
    Subject: Re: I want my expression to effect only one axis of a layer’s position
    Start here if you suffer from expression-transgression:
    https://www.motionscript.com/
    https://www.jjgifford.com/expressions/index.html
  • Criis Daw
    November 10, 2005 at 10:00 pm
    Thabk you both for your help.. i will try it now
  • Criis Daw
    November 10, 2005 at 10:22 pm
    HEY HEY hEY it works !!!!!!!!!!!!!!!!
    let the revolutuion begin
    how do you change it to move on the x axis??
    thanks
  • Mike Clasby
    November 11, 2005 at 2:07 am
    Change the last line to this:
    value + [temp, 0, 0]
    Actually I just realized the last line is set up for 3D [x, y, z],
    so to wiggle on the z (if 3D button is on) would be:
    value + [0, 0, temp]
