Activity Forums Apple Motion X Y Coordinate problem
  • X Y Coordinate problem
    Posted by Bill Mcguire on February 28, 2006 at 5:33 am
    I’ve noticed the inspectors coordinate system is not based upon the canvas, but apparently on the object. When I resize or move an image, lets say, the right top and botton x y coordinates will be one reading, but if I slide an image into that side, the left top and bottom coordinates of the abutted image will be entirely different.
    If, on the other hand, I turn on the coordinate visual on the top of the canvas, the readings will apparently be from the canvas, but I am unable to use them as I drag an image corner around. I have to continually let up on the dragging and then put my pointer over the spot I believe to be correct, and then adjust it a few times to get the correct coordinate.
    Is there a way to possibly have the inspector coordinates match the canvas, or to have the canvas coordinates react to my dragging? It is probably a simple task that I have not yet discovered.
    BTW: using Motion 2
    thanks much
    Bill Mcguire replied 20 years, 6 months ago 2 Members · 2 Replies
  • Jim Kanter
    March 2, 2006 at 1:48 am
    X Y coordinates in which property/parameter specifically? Position or anchor point?
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Bill Mcguire
    March 2, 2006 at 6:35 pm
    Yes, I am doing some corner pinning on layers. There must be a reason for not having the positions display canvas viewing coordinates… or a way to figure out the corresponding points on multiple layers, but I haven’t found the info in the PDF Manual.
