Activity › Forums › Apple Final Cut Pro › X-Title for Captions
  • X-Title for Captions
    Posted by Andreas Kiel on April 22, 2018 at 12:44 pm
    X-Title Importer for Caption just went online.
    It gives you the freedom to convert dfxp (itt and others), sami, sbv, srt, stl, vtt, untimed text etc into either Titles or ITT captions projects with full role support for both types.
    Simply select the target type and your subtitle source.
    While it is technically not a problem to include CEA it doesn’t make sense. FCPX doesn’t support CEA 708, means not all languages are supported. Additionally from my experience 99% of subtitle sources are not “CEA safe” and will result in a project with 100s of errors.
    https://www.spherico.com/filmtools/TitleExchange/XTI/XTI_B.dmg
    – Andreas
    Spherico
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
    Andreas Kiel replied 8 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
