Activity Forums Storage & Archiving X serve raid VS G-speed XL
  • X serve raid VS G-speed XL
    Posted by Juan Carlos aguirre on July 9, 2007 at 10:44 pm
    Hi all.
    We are trying to upgrade our SAN system, right now we have an 7Tb Xraid (3.5 Raid 5) each side, with fibre hooked to 3 systems via Sanbox 5200, and works fine for SD. I hear that Xraid is slow for HD, (slow beast they said) but not sure.
    Also I heard about G-speed Xl, and another systems, out there, is there worthed to uograde, are they really faster.
    We are planning to work with DVCproHD, and some times uncompress HD.
    Any clues ?
    Jeff Bernstein replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jeff Bernstein
    July 25, 2007 at 7:46 am
    Quite frankly, if you are working in mostly DVCProHD, then you really don’t need a faster RAID. The data rate per stream needed maxes out at around 14MB/second, worst case scenario, depending on resolution and frame rate.
    In general, the G-Speed XL is faster, not only in its throughput, but also in its ability to format/rebuild, and its ability to maintain a higher data rate while in a deprecated state.
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    MetaSAN Master Reseller
    323-653-7611
