Activity Forums Adobe After Effects X-rotation in 3D
  • X-rotation in 3D
    Posted by Gabriel Aronson on February 11, 2019 at 5:22 pm
    Hi all,
    I’ve been using AE for years I feel like I’m going crazy. As of cc2019 when I’m rotating layers in 3d space using the rotations in the layer panel, y and z rotations seem to do it along the local rotation widgets axes (blue and green). However once i’ve done a transformation in, say, the z-axis, the x-rotation seems to rotate around a global horizontal axis, not the local red x-axis they way I’d expect.
    I want x rotations to behave like the other axes, and i feel like that’s how it used to work for me for the past decade, and i’m really second-guessing myself. Is there some sort of preference I’ve somehow activated?
    I just want the x-rotation to rotate along the objects x-axis, not the global x-axis!
    Any advice would be appreciated, even if it’s telling me I’m crazy.
    Filip Vandueren replied 6 years ago 5 Members · 4 Replies
  • Cassius Marques
    February 11, 2019 at 6:03 pm
    That seems to be the normal behavior. I’d suggest you parent it to nulls. Use one for each axis, and rotate just that axis in each null.
    Cassius Marques
    http://www.zapfilmes.com
  • Greg Gesch
    February 11, 2019 at 11:59 pm
    Hi. Have you accidentally changed the Local/World Axis buttons at the top of your screen?
  • Mike Diluigi
    August 24, 2020 at 8:50 pm
    I’m having the same issue and it’s driving me nuts! And I don’t want to clutter my scene with rotation nulls for every 3D object.
  • Filip Vandueren
    August 25, 2020 at 7:18 pm
    There’s three tiny icons in the toolbar to select the Axis Mode: Local Axis, World Axis or View Axis.
