Activity Forums Adobe After Effects Expressions X rotation affects toWorld/toComp properties
  • X rotation affects toWorld/toComp properties
    Posted by Crystal Qn on March 4, 2022 at 3:07 am
    I have been trying to get the world coordinates of a 3D Layer, everything has worked as intended but when I animate the 3D layer’s X rotation, that affects the Y and Z axis numbers in toWorld(anchorPoint).
    I have added another expression for the anchorPoint to always be in the center of a layer, so probably it should not be moving?
    Is the only solution to make another layer that’s parented to said 3D layer, or am I missing something?
    Crystal Qn replied 4 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 4, 2022 at 3:48 am
    What’s the expression for the anchor point?
  • Crystal Qn
    March 4, 2022 at 4:17 am
    boxTop = thisLayer.sourceRectAtTime(time).top;
    boxHeight = thisLayer.sourceRectAtTime(time).height;
    boxLeft = thisLayer.sourceRectAtTime(time).left;
    boxWidth = thisLayer.sourceRectAtTime(time).width;
    [boxLeft + boxWidth/2, boxTop + boxHeight/2 ];
    Been fiddling and I stumbled the solution to my issues, I just had to add the 3D layer’s anchorPoint into toWorld() instead of adding on top of it
