Activity Forums Maxon Cinema 4D X-Ref
  • Posted by Robyn Rhodes on May 11, 2011 at 3:16 pm
    Can anyone point me towards good resources for understanding basics of xRef objects please?
    What I need to do replace an object in one project with an object from another. I need textures to come with the object, and for the object to inherit the keyframes of the object being replaced.
    R
    I’m only half the thing I say I am, the other half are me.
    Brian Jones replied 15 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    May 11, 2011 at 4:42 pm
    just check out the help for a start. XRefs are very simple really they are like instances except instead of referencing (and copying) an object inside your current scene, xrefs reference a model (or scene) that was saved earlier to a .c4d file. An object in a scene can also be converted to an xref (which saves it to a file as well) but if it was animated the animation gets saved in the xref. In your case I would save all your phones (just the phone objects) to their own files (make sure they are all at the spot in space in each of the scenes). Use one of them as a xref in your scene, animate it, once done you can then just change the link inside the xref and a different phone object will be referenced but will use the same animation. That’s why it’s important to make sure they are lined up the same first.
