Activity › Forums › Maxon Cinema 4D › X-ref and external composition
  • Adam Trachtenberg
    April 13, 2009 at 10:54 pm
    If you just want an object buffer for the xref, put the compositing tag on the xref object.
  • Gon Perdigao
    April 13, 2009 at 11:34 pm
    i try to put a tag inside of the xref project and i render, and no null object was imported to Afeter effects, i try also putting one out side in the global project, and i had a null, but the null wasn’t parent to the object, but to the position of the xref position.
    I try also with a composition tag inside of the xref project and also in the outside in the global project in the xref object, and no luck
  • Adam Trachtenberg
    April 13, 2009 at 11:54 pm
    Are you trying to get position data, an object buffer, or both?
  • Gon Perdigao
    April 14, 2009 at 12:12 am
    i’m trying to get both
  • Adam Trachtenberg
    April 14, 2009 at 2:52 pm
    I think you will have to convert your Xref to real objects in order to get 3D data out.
  • Gon Perdigao
    April 14, 2009 at 5:03 pm
    and how do i convert the Xref to real objects in order to get 3D data out?
  • Adam Trachtenberg
    April 14, 2009 at 6:04 pm
    Right-click>make editable.
