Activity Forums Apple Final Cut Pro Legacy X Raid, FCP capture question
  • X Raid, FCP capture question
    Posted by George Orallo on August 14, 2007 at 3:03 am
    I’m running FCP 5
    G5 OS 10
    I can only capture about 20 sec of Uncompressed 10 bit NTSC video, then FCP tells me it has dropped frame. I have the X Raid in a RAID 50 and I have 1TB of free space. Am I missing something?
    George
    George Orallo replied 19 years, 1 month ago 4 Members · 4 Replies
  • Raymond Tuquero
    August 14, 2007 at 3:31 am
    This is something that alot of people keep running into. I would check your Raid Admin settings. I beleive in the “settings”, there is a flush memory box, that is checked, by default. You are going to want to turn that off.
    Look into the Raid section of the Topics on here.
    Good Luck,
    Raymond Tuquero
    Houston Editor
  • Mark Raudonis
    August 14, 2007 at 6:01 am
    In your Raid admin settings, you want to disable “Host Cache Flushing”.
    Look at this:
    https://docs.info.apple.com/article.html?artnum=303503
    Mark
  • Peter Wiggins
    August 14, 2007 at 6:57 am
    I had the same problem, resettting the controllers in RAID admin fixed it.
    Peter
  • George Orallo
    August 14, 2007 at 5:54 pm
    Awsome,
    Thanks a lot guys.
