Activity › Forums › Maxon Cinema 4D › x-particles trails question
  • x-particles trails question
    Posted by Chad Demoss on March 22, 2016 at 10:27 pm
    I’m fairly new to this so it’s probably not the hardest question. I have a xpEmitter and its working fine. Now i want to add trails to the particles So i added an xpTrail, linked the emitter to it and when I hit play I see the trails animating but when I render a frame I only see the particles without any trails.
    what am i missing?
    Brian Jones replied 10 years, 6 months ago 2 Members · 1 Reply
  • Brian Jones
    March 22, 2016 at 11:33 pm
    the trails are splines and splines don’t render by themselves. You need to put the splines (the trail object) in a Sweep or XPSkinner for actual geometry or add an xpMaterial or Hair material to the xpTrail to see just the splines rendered or use Sketch and Toon to render the splines
