Activity Forums Maxon Cinema 4D x-particles keep pushing through objects with collider tags
  • x-particles keep pushing through objects with collider tags
    Posted by Jon Simpson on June 5, 2015 at 1:45 pm
    I have placed some planes to constrain the flow of particles downward, keeping them inside a specific rectangular area. I have put collider tags on the planes and the particles but some are getting through and I cannot figure out how. The emitter is sufficiently inside the boundaries I have set up and the particles are colliding properly with other objects in the scene. What could be happening here?
    Adam Trachtenberg replied 11 years, 3 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    June 5, 2015 at 3:11 pm
    You probably need to increase the subframe steps settings, which you’ll find in the Cinema Project Settings (Edit menu) under the X-Particles tab.
  • Jon Simpson
    June 8, 2015 at 2:03 pm
    Thanks Adam, but this is not working. Under the Expert tab I have set the steps per frame to 50, the maximum solver iterations to 50 and I still get errors. Also, when you say “under the X-particles tab” I do not understand. I see no tab for x-particles in the projects settings.
  • Adam Trachtenberg
    June 8, 2015 at 7:36 pm
    I’m using X-Particles 3. I forgot that version 2 doesn’t have subframe options. I guess you could try using the Cinema collision engine instead of the one in X-Particles. You’ll find an explanation of how to set that up in the X-Particles manual.
