Activity Forums Maxon Cinema 4D X-Particles get stuck when using xpFollowSurface modifier
  • X-Particles get stuck when using xpFollowSurface modifier
    Posted by Sascha Koeth on February 3, 2020 at 9:01 pm
    Hi everybody,
    I have the problem that xparticles controlled by the xpfollowsurface modifier are getting stuck on “corners” or “endpoints” of the meshed spline the are following on.
    In some constellations they get stuck in others they don´t.
    Here´s a simple example:
    https://wetransfer.com/downloads/87f8961a56815d14b6ffc98f08f6ec8a20200203201026/36b591
    The problem is in the final project the setup is so complex, that I can not try many different spline constellations and can not adjust “Pull” or “Distance” to make all particles keep from getting stuck.
    Is there any core issue that I am overseeing or a workaround?
    Sascha
    HAYWOOD Digital Studio
    http://www.haywood.de
    Sascha Koeth replied 6 years, 7 months ago 2 Members · 2 Replies
  • Sam Treadway
    February 4, 2020 at 2:11 am
    In the xpFollowSurface object at the bottom of the Object tab, turn on “Accurate”.
    In the xpSplineMesher object at the bottom of the Object tab, set the subdivision level to 1.
    The particles will round the sharp corners but will twirl around the surface once.
  • Sascha Koeth
    February 4, 2020 at 2:26 am
    Hi Sam,
    had to push the subdivision up to two to make it work but the 2 values are doing the trick! Thanks a lot!
