Activity Forums Maxon Cinema 4D x-particles emit second object
  • x-particles emit second object
    Posted by Gene Weglarz on March 5, 2016 at 12:53 pm
    I have a scene where the x-particles emitter is emitting the text as an object and using the texture as where to emit from so the text
    dissolves.
    https://vimeo.com/157285124
    Now I want the text to use a feather as the particle it dissolves to. Do I have to use another emitter an how would I make sure it’s following the line for the emitter emitting texture from text?
    G. Weglarz
    Gene Weglarz replied 10 years, 6 months ago 2 Members · 4 Replies
  • Brian Jones
    March 5, 2016 at 4:21 pm
    those are x-particles with an x-particle shader? If so, then just add an xpGenerator object with the feather as a child of it
  • Gene Weglarz
    March 6, 2016 at 2:28 am
    I’m using a texture for the emitter with the text. Here’s a link to the C4D file – at the bottom of the page. https://fluid-productions.net/home/about-us/
    G. Weglarz
  • Brian Jones
    March 6, 2016 at 6:15 am
    here’s a modification using a simpler ‘feather’ object for testing. The feathers go in the xpGenerator which feeds them to the xpEmitter 9856_xparticlesemitobject2.c4d.zip
  • Gene Weglarz
    March 6, 2016 at 7:28 pm
    Can’t seem to get the feather object to be recognized by the emitter.
    G. Weglarz
