Activity › Forums › Apple Final Cut Pro › X-Files Pro Public Beta
  • James Cude
    June 12, 2013 at 5:57 pm
    Looks like a great util. I would recommend a slight name change to avoid any trouble from the folks over at Fox though…https://en.wikipedia.org/wiki/The_X-Files
  • Andreas Kiel
    June 12, 2013 at 8:06 pm
    there shouldn’t be any conflict using that name. i’ve read some legal stuff.
    the app has nothing in common with scifi (i hope — ask apple about x files), i’m not selling mugs or t-shirts etc.
    in case there would be problems, i will change the name to fcp x-files.
    -andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • Bill Rabkin
    June 13, 2013 at 9:31 pm
    I downloaded, installed, and launched the X-Files Pro Public Beta. It displayed my external FW800 drives in its “Final Cut Pro X Volumes” window, which shows 8 drives (7 of which are “True” for FCP X; the other drive is my Time Machine backup drive).
    However, all menu choices in the “Events & Projects” menu pull-down are disabled (greyed out). This is still true if I select a drive in the “Volumes” window.
    How do I manage Events and Projects?
    Suggestion: Don’t use Command+P for the “Manage Events & Projects” command. That shortcut is widely used for “File > Print.”
    FastBill
  • Andreas Kiel
    June 13, 2013 at 10:20 pm
    Bill,
    sorry, seems I have swapped versions on the server. i will fix that tomorrow morning (european time).
    thanks for the feedback.
    -andreas
    Spherico
  • Andreas Kiel
    June 14, 2013 at 7:20 am
    Hi all,
    The correct version is back on the server.
    -Andreas
    Spherico
