Activity Forums Adobe After Effects X-Factor Grid
  • X-Factor Grid
    Posted by Charley King on September 23, 2005 at 10:21 pm
    I have been totally unable to figure out how to configure this to happen, and how to get it to see the second computer. And I have not been able to find any step by step instructions. Anybody game to help this old dog learn a new trick?
    Thanx
    Charlie
    Charley King replied 20 years, 11 months ago 2 Members · 2 Replies
  • Deleted User
    September 24, 2005 at 3:16 am
    Hello Charlie,
    You have 2 Ethernet cards in eother pc, you then connect via a ethernet cable pc – pc or via a network hub, if you are on Microsoft Windows XP you have an option to setup a home Network, you can use the wizard and setup a network which is not on the internet.
    Machine 1: After Effects Work station with Grid Iron
    IP: 192.168.0.4
    Machine 2: After Effects Render engine and grid iron
    IP: 192.168.0.5
    You can set the ip’s manually in Microsoft XP by going to control pnale netwrok connections, then right clicking properties, then TCP/IP then configuring a mamnual IP.
    In After Effects you then create a watch folder and configure the gridiron to use the IP on the 2nd pc. I have only used the Gridirin once ages ages. So very rough.
    Hope this helps?
    LEO BAKER
    SYNC FILMS
    Web: http://www.syncfilms.com
    E-Mail: leo@syncfilms.com
  • Charley King
    September 26, 2005 at 4:16 pm
    Sorry I guess I should have stated more information, I am already networked. I can’t find how to actually start X-Factor. Especially since Help in X-Factor has one listing “About” the version number doesn’t really tell me how to use it. hahaha
    I’ll play around some more and see first if I can figure it out, and second if it really helps any.
    Thanx
    Charlie
