Activity Forums Adobe After Effects Expressions X and Y position modifier
  • X and Y position modifier
    Posted by Allen Joaquin on January 9, 2014 at 2:36 pm
    hello, i am trying to link the x and y position of a null object to the x and y position of the effect ¨CC Cylinder¨
    Now the problem is that the value position of X in the null object is 614 and 614 for the cylinder would be 80.
    Which means the middle of the comp for the cylinder is [0] but for the null object the middle would be 640.
    The values are different, is there any way to make them equal? idk if i can explain myself, i basicly i want the cc cylinder effect to follow the null object x and y positon.
    Allen Joaquin replied 12 years, 7 months ago 2 Members · 4 Replies
  • Dan Ebberts
    January 9, 2014 at 5:06 pm
    I think it’s going to look like this for x:
    fromComp(thisComp.layer(“Null 1”).transform.position)[0]-width/2
    and this for y:
    fromComp(thisComp.layer(“Null 1”).transform.position)[1]-height/2
  • Allen Joaquin
    January 9, 2014 at 5:15 pm
    Could you explain the expression used here? id like to know what it is exactly doing in case i´d like to modify it!
    Thanks a lot.
  • Dan Ebberts
    January 9, 2014 at 5:20 pm
    fromComp() converts the null’s coordinates from comp space to the layer’s space, [0] gives you the x component, -width/2 corrects for the fact that [0,0] in layer space is the upper left corner but it’s the center of the layer for CC Cylinder.
    Dan
  • Allen Joaquin
    January 9, 2014 at 5:55 pm
    thank you very much
