Activity Forums Adobe After Effects Expressions x and y expression
  • x and y expression
    Posted by Jack Parks on September 17, 2008 at 11:24 am
    I’ve been looking on the forum for an expression and the closest thing I could find are ones where the blur or opacity is affected by a layers z position.
    I would like a layers opacity to be (example)100% when at the centre of the comp, and falloff as the layer nears the edges (moves around x and y) (a slider would be handy so the opacity near the edge could be modified, 25% or 0% etc).
    A basic expression would be really helpful that could be modified and used for opacity or on a blur etc.
    I was trying to set it up based on a toWorld(?) as it would be great if it was flexible to use in different sized projects.
    (Also if z information is included that would be great too).
    Any suggestions would be appreciated.
    (Sorry if this has already been looked at in another post).
    Jack Parks replied 18 years ago 2 Members · 4 Replies
  • Mike Clasby
    September 18, 2008 at 1:25 am
    This seems to do what you want. Put a slider on a New Null (to adjust the distance that the layers opacity reacts too like you asked for). Put the expression on the layer’s opacity:
    d = thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”);
    point1=this_layer.position;
    x = this_comp.width/2;
    y = this_comp.height/2;
    point2=[x,y];
    delta=sub(point1, point2);// Find the vector between them
    distance=length(delta);// Now find the length
    linear(distance, d, 0, 0, 100);
    It’s a hack from Dan’s stuff.
    If you want an ease on the interpolation change the last line to:
    easeIn(distance, d, 0, 0, 100);
    or
    easeOut(distance, d, 0, 0, 100);
  • Jack Parks
    September 18, 2008 at 2:06 pm
    Thanks for your help I really appreciate it.
    Sorry but I think I am getting something wrong though, the expression seems to have no effect.
    I set up a new comp for a test, with Null 1 and a slider, and a white solid with the expression on opacity.
    I keyframed the white solid to move from top left corner to bottom right corner.
    The solid doesn’t seem to change opacity, moving the slider results in 0% or 100%.
    [The effect I had hoped for was increasing opacity nearer the centre]
    Sorry I think I must have missed something even though it’s so simple.
    Any tips would be great.
    Thanks again.
  • Mike Clasby
    September 18, 2008 at 4:58 pm
    d = thisComp.layer("Null 1").effect("Slider Control")("Slider");
    point2=[x,y];
    linear(distance, d, 0, 100, 0);
    The correct code is above it works for me as avertised (as setup in my first post), but the original code I gave you did the opposite, it fades out as it approaches the center, here’s the correct last line:
  • Jack Parks
    September 18, 2008 at 7:04 pm
    Thanks for your patience, you’re right it does work, I hadn’t got the slider at a high enough value. Sorry my bad.
    It’s great thanks for your help.
    Cheers
