Activity › Forums › Adobe Premiere Pro › WTF?!?!?! 2015 does NOT PLAY AT ALL!
Posted by Ze’ev Gilad on June 30, 2015 at 8:44 amCome on, Adobe, get it together!
After editing for 2 hours, Premiere 2015 does NOT PLAY ANYTHING AT ALL on my system.
Only shows still frames.Tried deleting all the cache/db/media crap. Nothing.
And, of course, I can no longer open my project in 2014, it’s a new format.
Thanks, Adobe, you guys are so on the ball.
Ben Whisenhunt replied 11 years, 1 month ago 8 Members · 10 Replies -
Michael Hendrix
June 30, 2015 at 12:34 pmL key or SPACEBAR will turn still frames into moving video.
Ze’ev Gilad
June 30, 2015 at 12:48 pmYou’re kidding, right?
Turns out a bunch of people are having this issue on the Adobe forum.
I just finished a chat with Adobe Tech Support.
After 3 hours of diddling around my machine, he finally said “sorry, I need to to escalate this, we’ll be in touch within 48 hours.”What a colossal waste of time.
I wish Adobe would try to make things STABLE and actually WORK and FIX BUGS
before releasing exotic new features that will get used by nearly no one -
Yair Bartal
June 30, 2015 at 1:00 pmYou may have missed the point.
YOU are making the QC of the latest version.
If you don’t want that, just stay at least one version behind.
Especially behind x.0 versions. -
Michael Hendrix
June 30, 2015 at 1:08 pmNo, not kidding, it really does work, just like my copy of 2015. Context around posts are an important thing. Not sure if your are just venting, looking for help or something else.
Even posting your configuration can help, if others are having problems with the same config or are not, helps to narrow down which systems are having the problem.
Andrew Kimery
June 30, 2015 at 7:27 pmHave you tried exporting your project as an XML and opening up that XML in CC2014?
[Ze'ev Gilad] “I wish Adobe would try to make things STABLE and actually WORK and FIX BUGS
before releasing exotic new features that will get used by nearly no one”That’s a problem with software in general which is why it’s always always a good idea to wait to update unless you like wading into uncharted waters (and it obviously looks like you do not like wading into uncharted waters).
Kevin Monahan
July 1, 2015 at 8:00 amHi,
I don’t recommend updating project files. Wait till you’re done with your CC 2014 project before moving on. Here’s my blog: https://blogs.adobe.com/kevinmonahan/2015/06/16/updating-and-backing-up-project-files-best-practices/It’s actually an editors long standing R.O.T.
Kevin -
Steve Brame
July 1, 2015 at 10:51 amYep. My first trial at opening a 2014 project in 2015 resulted in the age-old .mts files suddenly being ‘unsupported’ issue. The (also) age-old fix of renaming the base folder for the files took care of it, but that was enough to abandon the trial with a live project.
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
“98% of all computer issues can be solved by simply pressing ‘F1’.”
Steve Brame
creative illusions Productions -
Kevin Monahan
July 3, 2015 at 12:28 amHi,
Sorry my first response was more snarky than helpful. Others have solved this issue by adjusting Audio Hardware preferences: https://forums.adobe.com/message/6497216#6497216Thanks,
Kevin -
John Mayer
July 3, 2015 at 2:43 amhad this issue not long ago, when I had CC2014. Turns out it was nVidia driver’s fault. I updated to newer driver and it fixed the issue.
Ben Whisenhunt
August 1, 2015 at 1:45 amYa, man there are a lot of people in this boat, it’s a major bug that is not persisting in 9.0.1. hopefully your not too far into the project but just export an xml and reinstall 8.2 and import the xml. They can actually both installed on the system at the same time.
Sucks but I’m sure they will have it fixed soon. There are a ton of people complaining over on the adobe forums.
This thread is updating regularly:
https://forums.adobe.com/thread/1881838?tstart=0
