Activity › Forums › DaVinci Resolve › wrong start TC
  • wrong start TC
    Posted by Sergey Stankov on December 23, 2015 at 8:15 am
    Hello!
    I’ve got this issue with Davinci (though as I can see there were posts concerning this topic already, the solution still wouldnt show up):
    When I try to import an XML from Adobe Premiere I get this: “failed to link because the media file is missing or has the wrong timecode extents.”
    When I force conform I get the timeshift, as to the rest, the timeline is imported ok.
    Video is h264 mp4 with sound, UHD, 29.97 drop frame.
    Start TC’s of couple of pieces of video:
    First file:
    Adobe Premiere: 15:28:26:07
    Sony Vegas: 15:28:26:07
    DaVinci Resolve: 15:28:26:47 (as shown in DaVinci file manager)
    15:28:27:17 (as shown in the media pool file info)
    Second file:
    Adobe Premiere: 15:28:42:07
    Sony Vegas: 15:28:42:07
    DaVinci Resolve: 15:28:42:47 (file manager)
    15:28:43:17 (media pool)
    In the settings of DaVinci:
    project frame rate matches the video
    master settings\conform: use timecode “embedded in the source clip”, “assist using reel names” checked off
    On import:
    Automatically set project settings: checked off
    Automatically import source clips: checked off
    PS. I’ve been able to partially solve the problem by exporting AAF from Premiere, changing all videos TC’s to zero before that. Then in DaVinci I’ve set use timecode “from the source clip framecount”. Everything went ok, though AAF doesn’t support some things XML does, so I’d prefer XML. This trick doesn’t work with XML though.
    Thank you!
    Connor Lee replied 6 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Glenn Sakatch
    December 23, 2015 at 3:59 pm
    is your premiere timeline 23.98?
    Glenn
  • Sergey Stankov
    December 26, 2015 at 4:52 pm
    the TL fps is set to 29.97 (tried dropframe/ non df to no avail)
  • Glenn Sakatch
    December 26, 2015 at 5:25 pm
    Where is your source video from? Is this camera original Go Pro? or has it been transcoded/converted somewhere along the way?
    Can you upload one of these clips, again with a note of what you are seeing on the timecode. I’d like to see what Resolve and Avid show me.
    I’m not a user of premiere and when I have used it, if it has to do any kind of fps conversion, I find I usually screws it up for any kink of list creation.
    The two different timecodes in Resolve (although they are both showing the same time in a 30fps timeline) are interesting.
    Glenn
  • Sergey Stankov
    December 28, 2015 at 2:14 pm
    Sorry, cannot provide a piece of footage because of the privacy thing, but it is some Sony camera footage: folder is called M4ROOT and files are XAVC AVC .mp4, 3840×2160, 29.970 fps. It hasn’t been transcoded.
    I’ve also attached screenshots from DaVinci/Premiere with those timecodes.
  • Connor Lee
    November 12, 2019 at 4:30 pm
    Hey everyone. I just thought I would post here because it took me forever to figure this out. If you want to have all your clips start with a 0 for the timecode start with a new project without any clips in it. click on the gear in the bottom right corner. go to general options. click use timecode from source clip frame count. click save. THEN import your files into davinci resolve. the time code will only be 0 for clips imported AFTER you click this option.
  • Glenn Sakatch
    November 12, 2019 at 11:55 pm
    Why are you posting that here?
    That is a totally different topic.
    The OP was referring to footage that had incorrect Timecode
    To make the solution you are talking about useful to people, itshould be in a separate post with a proper heading that refers to what you are talking about.
    Then if search for a topic on “starting source Timecode at 0″…I can find your listing.
    Glenn
  • Connor Lee
    November 13, 2019 at 7:00 pm
    I apologize I must have clicked the wrong link
