Activity Forums Apple Final Cut Pro Legacy Wrong Sequence settings
  • Wrong Sequence settings
    Posted by Russ Carlin on February 28, 2012 at 1:59 pm
    Just looked at frame rates and saw on Ken Stones website that if you are shooting in different frame rates (in my instance, 29fps and 59fps) then the sequence settings should be to edit in 59fps as you should always up convert your frame rate.
    Is this true? and if so can i change the Sequence Frame rate up to 59 at all? Or do i have to restart?
    Cheers!
    Russ
    Carrrrrrr Carrrrrrrrrrrrr
    Russ Carlin replied 14 years, 6 months ago 2 Members · 2 Replies
  • Joseph Owens
    February 28, 2012 at 10:11 pm
    Hard and fast rules are quite entertaining these days.
    59.94 is a 720P format and you’ll be fine with 29.97 for everything else. Watch your interlacing dominance. External applications that make assumptions about the framerate of source media with respect to the sequence settings will introduce mismatches in trims and durations.
    You cannot change the framerate of a sequence once you have added media to it.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Russ Carlin
    February 29, 2012 at 11:48 am
    Ok so i should be alright with it? Yea i shot the 59fps in 1280 x 720p and the other footage in 1920 x 1080.
    There is no field dominance on any of it as i converted all the footage using mpeg streamclip to use with ProRes 422. I think i (must have!) De-interlaced all the 1080 footage.
    Cheers!
    Russ
