Activity Forums Apple Final Cut Pro Legacy Wrong Part of Source Clip When I Export
  • Wrong Part of Source Clip When I Export
    Posted by Matt Hargrave on December 7, 2009 at 10:06 am
    I have a Final Cut sequence that behaves very oddly when I export it. It is a montage with clips from many different projects in it. When I export it to a QT clips from one project play the wrong part of the source clip. When I go back to Final Cut it plays fine in the sequence but always plays the source clip about 8 seconds too early when I export. The rest of the exported QT always plays fine. Has anyone ever experienced this or does anyone have any suggestions?
    Matt Hargrave replied 16 years, 9 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    December 8, 2009 at 12:11 am
    Are the clips named properly and do they match the names of the QT movies they reference? i.e, not untitiled 1, 2, 3 etc.? I could see where this would present a problem like this maybe?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jerry Hofmann
    December 8, 2009 at 12:13 am
    Might try trashing all renders and re rendering.. or copy and paste the clips to a new sequence, trash the renders and re render…
    Jerry
  • Matt Hargrave
    December 9, 2009 at 2:16 am
    Yep, the names all match up. I tried your second thought about copy and pasting and re-rendering with no luck. I had to export the original clip and re-insert it in all the places it was featured. This took a while but it worked. Hopefully I won’t encounter this again.
