Activity Forums Maxon Cinema 4D Wrong movement from one point to another
  • Wrong movement from one point to another
    Posted by Yuri Winkelman on February 15, 2017 at 9:20 am
    Hello community,
    I run into problems regarding an animation. The object (which is grouped and consist of 2 parts) moves from one point to another. During the movement I added a 360 turn + a slide change of angle. Though the object moves weird and not turns around it’s Axis. At least not the straight movement I want.
    Starting point
    The idea is that it rolls 360, but what happens it turns 360 horizontal
    I hope this explanation does make sense. I’m quite new to Cinema4D and appreciate any feedback!
    Best,
    Yuri
    Yuri Winkelman replied 9 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 15, 2017 at 9:29 pm
    Hard to tell from the pics, but my guess is that you’re experiencing an order of rotation problem. You can see the problem illustrated if you activate the rotation tool and then check the “gimbaling rotation” box in the attributes manager. The best way to avoid it is to nest your object in a series of nulls. Instead of animating the object’s rotation, animate the nulls’ rotations (one axis per null).
  • Yuri Winkelman
    February 17, 2017 at 10:42 am
    Hi Adam,
    thank you for your reply. Much appreciated.
    For now it seems to work.
