Activity Forums Maxon Cinema 4D Wrong Build ID with Team Render
  • Wrong Build ID with Team Render
    Posted by Thomas Frank on August 11, 2014 at 6:47 am
    I updated Cinema 4D with the let latest update which all works fine as expected.
    But now I em getting Wrong Build ID for my Team Render Clients.
    Is this because I updated the main application if so how do I update the Team Render Clients I don’t see a update menu?
    Jan Vork replied 11 years, 11 months ago 2 Members · 3 Replies
  • Thomas Frank
    August 11, 2014 at 6:51 am
    Never mind I found the update under Help…
  • Jan Vork
    October 13, 2014 at 7:01 am
    Hi Thomas, I don’t see any Help in R16’s Teamrender.
    Having the same problem you described at first: wrong build id, but not knowing how to update.
    Where did you find the Help?
    Jan
    http://www.jaydude.nl
  • Jan Vork
    October 13, 2014 at 7:24 am
    Ah, found it. Trashed all Preferences (was always wondering why there was a button to get me directly in the Preferences folder…).
    After removing the Preferences, the auto-updater showed up.
