Activity Forums Apple Final Cut Pro Legacy Wrong aspect ration exporting from Compressor
  • Wrong aspect ration exporting from Compressor
    Posted by Samah Bennett on February 6, 2009 at 11:21 am
    I am working with FCP 6 on my MacBook Pro, and exporting a 720p24 sequence through Compressor and going using one of the web download options for Quicktime 7.
    It’s a 16×9 piece, and I am going into the geometry parameters to make sure it’s exporting for 16×9. I’ve done this hundreds of times before, but for some reason the finished product is not 16×9, but square, seemingly 4:3.
    Anyone know where this bug might be coming from and how I can solve it?
    Many thanks in advance.
    Samah Bennett replied 17 years, 7 months ago 4 Members · 5 Replies
  • Rafael Amador
    February 6, 2009 at 11:47 am
    Hi Samath,
    [Samah Bennett] “It’s a 16×9 piece, and I am going into the geometry parameters to make sure it’s exporting for 16×9. I’ve done this hundreds of times before,”
    If your master is 16×9 you don’t need to do nothing in the “geometry parameters”, but to set the proper size in Square pixels.
    The “wide x high” of your web movie must ALWAYS keep the 16×9, so feasible sizes are for example:
    – 160 x 90
    – 320 x 180
    – 400 x 270
    – 480 x 360
    Rafael
    http://www.nagavideo.com
  • Stephan Walfridsson
    February 6, 2009 at 2:49 pm
    [Rafael Amador] “The “wide x high” of your web movie must ALWAYS keep the 16×9, so feasible sizes are for example:
    – 160 x 90
    – 320 x 180
    – 400 x 270
    – 480 x 360
    I think you mean 480 x 270 and 640 x 360… 😉
    Stephan
  • Rafael Amador
    February 6, 2009 at 2:59 pm
    You are absolutely right.
    Should be:
    – 400 x 225 (careful with the Macroblocks structure ).
    – 480 x 270
    – 640 x 360.
    etc……
    rafael
  • Chris Poisson
    February 6, 2009 at 3:52 pm
    Samah,
    Assuming you are using DVDSP, in the inspector, you get an option to set the track to 16×9. It works the same as having your m2v set stretched out.
    Have a wonderful day.
  • Samah Bennett
    February 6, 2009 at 4:19 pm
    Thank you gentleman. Exporting this video for the web, the problem was that i forgot the width x heigth calculus. changes for the web. listening to all of you reminded me of that, and helped me solve the problem and I really appreciate it.
    s.
