Activity › Forums › Compression Techniques › Wrong aspect ratio when AVCHD converted to MP4
  • Wrong aspect ratio when AVCHD converted to MP4
    Posted by Johan Wadman on November 30, 2010 at 8:01 pm
    Hi!
    I have a video recorder from Sony producing AVCHD content and storing to memory card.
    It is stated to record at a 1080i.
    ffmpeg says that the original .mts-file is 1440×1080 with DAR 16:9 and PAR 4:3.
    ffmpeg –i 00001.MTS
    Input #0, mpegts, from '00001.MTS':
    Duration: 00:02:42.24, start: 1.000033, bitrate: 11531 kb/s
    Program 1
    Stream #0.0[0x1011]: Video: h264, yuv420p, 1440x1080 [PAR 4:3 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s
    Stream #0.2[0x1200]: Subtitle: pgssub
    The .MTS-container and the AC3-audio is not supported on my Samsung TV.
    Therefore I am converting it with ffmpeg to MP4 container and mp3 audio.
    I do this with
    ffmpeg -i 00001.MTS -vcodec copy -acodec libmp3lame output.mp4
    Program 1
    File 'output.mp4' already exists. Overwrite ? [y/N] y
    Output #0, mp4, to 'output.mp4':
    Metadata:
    encoder : Lavf52.64.2
    Stream #0.0: Video: libx264, yuv420p, 1440x1080 [PAR 4:3 DAR 16:9], q=2-31, 50 tbn, 25 tbc
    Stream #0.1: Audio: libmp3lame, 48000 Hz, stereo, s16, 64 kb/s
    The only problem is that when played on the Samsung TV it is shown as 4:3 content. (People look taller and black areas on left-end and right-end sides.)
    My guess is that Samsung TV don’t care about the PAR 4:3 and uses PAR 1:1 instead.
    Then since 1440/1080 equals 4/3 this is what I get.
    So I believe I need to convert 1440×1080 DAR 16:9,PAR4:3 to 1920×1080 DAR 16:9, PAR 1:1 ?
    The question is then how do I do that with ffmpeg???
    Best regards Johan
    Marcin Ok replied 13 years, 7 months ago 3 Members · 3 Replies
  • Michael Rampe
    December 1, 2010 at 1:42 am
    [johan wadman] “My guess is that Samsung TV don’t care about the PAR 4:3 and uses PAR 1:1 instead. So I believe I need to convert 1440×1080 DAR 16:9,PAR4:3 to 1920×1080 DAR 16:9, PAR 1:1 ?
    The question is then how do I do that with ffmpeg???”
    I agree. since the Samsung device is not respecting the container aspect flag, you will need to re-compress the stream instead of using -vcodec copy.
    As you have quite a high bitrate original, you will need to specify that.
    one pass example:
    ffmpeg -i 00001.MTS -vcodec libx264 -vpre medium -b 11000k -s 1920×1080 -aspect 16:9 -acodec libmp3lame -ab 256k output.mp4
    two pass example:
    ffmpeg -i 00001.MTS -vcodec libx264 -vpre medium_firstpass -b 11000k -bt 11000k -s 1920×1080 -aspect 16:9 -an -pass 1 /dev/null && ffmpeg -i 00001.MTS -vcodec libx264 -vpre medium -b 11000k -bt 11000k -s 1920×1080 -aspect 16:9 -acodec libmp3lame -ab 256k -pass 2 output.mp4
    Depending on the content, you should be able to get acceptable quality at a lower bitrate so do some experiments.
    Michael
  • Johan Wadman
    December 1, 2010 at 9:20 pm
    Hi!
    I just tested and now it is correctly displayed!
    Thanks Michael!
    /Johan
  • Marcin Ok
    March 2, 2013 at 11:38 am
    This is very helpful. Do you maybe also know how the command would look like to also convert 50p to 50i?
