Activity › Forums › Apple Final Cut Pro Legacy › Writting Video
  • Posted by Stevec on September 16, 2005 at 9:12 pm
    Hopefully someone out there can answer this.
    Why does FCP need to (sometimes) write video for a project prior to mastering to tape or “Edit to tape”/
    I completely rendered the project in FCP prior to going to Edit to tape mode, but it still says it needs to write video.
    Even when I let it do this and then start laying it to tape and have to stop for some reason, when I go to lay it down again it has to re-render again.
    An answer to this would be great, because it eats up a lot of time.
    Steve
    Stevec replied 21 years ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    September 16, 2005 at 10:46 pm
    That’s one of the reasons why I never ever use Print to Video.
    I just render the effects, MIXDOWN THE AUDIO, and play the timeline out to a tape.
  • Stevec
    September 19, 2005 at 12:15 pm
    I use Edit to tape, so that I can have my programs starting on the hour as well as being able to do insert edits if needed.
    The problem that I am having doesn’t happen all the time, but it does happen enough to make it frustrating, when you are dealing with 30 min shows.
    Steve
