Activity › Forums › Adobe After Effects › Writing with Particles
  • Writing with Particles
    Posted by Deleted User on October 4, 2008 at 9:01 pm
    Howdy! I am working in After Effects 7.0 (trying desperately to get the company to upgrade).
    I was messing around with the Star Trail animation preset and I thought it would be cool to write stuff with it and then have it fall as it faded out. I figured I would just set up a simple paint layer using the write on effect and then somehow (here’s the problem) get the producer to follow the paint stroke as it goes through the words. The error I get is you can’t mix spatial (producer) and temporal (paint write on) keyframes. I understand the error, but that still isn’t helping me to solve my problem.
    I may be going about this completely wrong too. If anyone has suggestions, I would appreciate it.
    Have a good weekend!
    G
    Geno A. Palazzari
    Creative Services Commerical Producer
    KAAL-TV
    Rochester, MN
    Deleted User replied 17 years, 12 months ago 3 Members · 3 Replies
  • Mark
    October 6, 2008 at 12:51 pm
    You can also use the masks to create the word using the stroke filter. Then create a duplicate of the that layer and animate the stroke in and out so that the numbers are very close (ie in 0 out .2 then end 99.8 out 100)….Now this will create a dot that follows the masks….now simply motion track this dot and use the particle producer point as the target.
    Regards
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • David Bogie
    October 6, 2008 at 3:24 pm
    Writing on the screen is never that simple. You must change some of the keyframes to holds to simulate pen lifts between words and to dot the Is or cross the Ts.
    bogiesan
  • Deleted User
    October 6, 2008 at 4:05 pm
    Acutally, I just make a keyframe where a word or letter ends and then copy and paste that keyframe a few frames laternsimulate the lifting of the pen. Didn’t think about holding keyframes… Might have to try that for fun. Thanks for the suggestion.
    Geno A. Palazzari
    KAAL-TV
    Rochester, MN
