Activity › Forums › VEGAS Pro › Writing Scripts / Magic Lantern
  • Steve Rhoden
    April 22, 2014 at 9:07 am
    Yep, that’s where to start.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • John Rofrano
    April 26, 2014 at 12:23 pm
    If you can describe what you need to do, I can point you in the right direction with regard to what API calls to read up on.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Russ Froze
    August 10, 2014 at 2:45 am
    Here is something that might be of use. By some fluke I managed to import the Magic lantern DNG files directly into Vegas Pro. Versions 10 – 13. The trick it seems is to install Adobe – DNG Codec – For Windows – Adobe DNG Codec 2.0.’>Adobe – DNG Codec – For Windows – Adobe DNG Codec 2.0. It’s a bit sluggish but it avoids hours of transcoding and the like. Using the MIRawViewer adjusting the white balance in conjunction with various other tools supplied with the viewer before exporting the DNG files is a real time saver. To finish off color grading I use Boris Red from the Vegas timeline where I can use the Three way color grade plugin. I’m curious to know if I am the only one to stumble across this workflow. I have it working on three separate machines now.
