Activity Forums Maxon Cinema 4D Writing on Water
  • Writing on Water
    Posted by Greg Paterson on September 1, 2005 at 6:02 am
    I am trying to work out the best way to create the impression of writing on water.
    The scene is a video of an actor facing the camera writing with their finger on a vertical plane of water. The ripples spread out and deform the entire frame.
    The intention is to use a plane with a water material and use a bump map to deform the plane.
    Creating the bump map is the concern ….. how.
    Is there a way to make something like a small sphere move along a path (matched to the actors finger movement) and deform the plane.?
    Is this possible?
    There must be a way easier than manual keyframing.
    This wont spread the ripples so something extra is needed …but what?
    Your guidance is sort.
    GReg
    Adam Trachtenberg replied 21 years ago 2 Members · 3 Replies
  • Adam Trachtenberg
    September 1, 2005 at 4:25 pm
    If you have AE Pro you should be able to do this with the Wave World plugin.
  • Greg Paterson
    September 2, 2005 at 12:09 am
    Greetings Adam
    [Adam Trachtenberg] “If you have AE Pro you should be able to do this with the Wave World plugin.”
    Life would always be easier with a big bag full of $$$$$……
    Unfortunately I dont have AE.
    Are there any “pocket friendly” plugins for C4D that could do this?
    GReg
  • Adam Trachtenberg
    September 2, 2005 at 2:03 am
    There’s a plugin called Add-The-Sea that *might* have this capability, but I’ve never tried it. https://www.motion-gimmick.net/english/index2_e.htm
