Activity › Forums › Adobe After Effects › Writing on text … is there an easier way?
Posted by David Tunnell on September 17, 2012 at 2:17 pmI have a client that has a product that simulates hand written documents and marketing material.
They want a LOT of text written on. Using the pen tool/stroke method is time consuming and tedious. So I tried creating masks from text layers, The font is a hand written font, so you end up with holes where the masks overlap, now that creates another tedious problem fixing all of the masks.
Has anyone anywhere created a plugin or script that allows this to be done easily and fast?
David Tunnell
TunnellVision ProductionsDavid Tunnell replied 12 years, 6 months ago 5 Members · 10 Replies -
Tom Daigon
September 17, 2012 at 2:29 pmNot that Im aware of.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
John Cuevas
September 17, 2012 at 2:38 pmI had to simulate writing on a chalkboard for a series of educational videos once. What I did was animated every letter A to Z and numbers 0-9 once and then just dropped them into the project as needed. Course this only works with printed letters, not script…but I thought I would throw it out there.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
David Tunnell
September 17, 2012 at 2:48 pmLooks like the text masking technique is my best bet then. Amazing all of the wonderful things AE can do, but this simple thing is not one of them
David Tunnell
TunnellVision Productions -
Joseph W. bourke
September 17, 2012 at 3:46 pmThink about that statement, David – it’s not a simple thing at all. Depending on the typeface you use, you have ascenders, descenders, serifs, bowls, and all other sorts of bits and pieces which are entirely different for every single one of the multiple thousands of fonts which are out there.
Now while I suppose someone could write a script which starts at the left hand side of the letter, and proceeds through the curve of the letter (oh…wait, this is the letter T, there’s no curve!), then progresses letter by letter through each word, then line, it just isn’t that simple. Look at the letter “T”. When you write it, do you do the crossbar at the top first, or the upright? Even better, look at the letter “G” – do you write it from right to left – well I do – then the whole system falls on its face…because in handwriting there is no system. It’s as unique as the person who writes, the country you’re writing in, the script style you choose, and so on and so on. You can’t write a plugin to mirror a system in which there is no system.
My suggestion is to charge the client what it’s really going to take you in time, and prepare to see them run the other way. That said, if there are large amounts of text being written that aren’t too close to the camera, you could use the Text Typewriter effect, and most people would be none the wiser.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
David Tunnell
September 17, 2012 at 3:48 pmI meant “simple” compared to say 3D???
David Tunnell
David Tunnell
September 17, 2012 at 5:07 pmI actually thought about having them do that, use the product and we actually see it write what they need. The problem is the expense of having the shooter come back out and do it.
What I have done, is explain the time it takes to do what they want and the expense f me doing it, which is slightly less than reshooting it and having one of their programmers set it all up.
So we have settled on 3 key scenes with me doing the write on, and then use the fade on character effect for the rest. It works pretty good.
I just thought I would ask. I have seen Maltannon, Dan Ebberts and others do some incredible things with expressions. Many times when I ask, somebody has figured it out. You never know until you ask.
David Tunnell
Joseph W. bourke
September 17, 2012 at 5:17 pmDavid –
Rather than shoot the screen, why not use something like Camtasia to actually capture the “writing on” process. It’s way cleaner looking than anything you could ever do with video, and it’s very quick to accomplish.
Joe Bourke
Bourke Media
David Tunnell
September 17, 2012 at 5:31 pmThe product is actually a hardware device,they program in the text, pick the type of handwritten font, ot even sample a clients handwriting, then the hardware actually uses a pen and it writes out the message, letter etc.
David Tunnell
Laurence Yates
February 23, 2014 at 10:05 pmThis may be too late for the OP, but there is now a plugin available for exactly this effect.
When I was faced with a project that was entirely write-on reveal I experimented with the Stroke Effect, Write-On effect and the Paint Effect. To bust through a lot of this kind of animation, I went for the Paint Effect and used my Wacom to trace all the line-work and text. You can then set keyframes for each Paint stroke individually, which gives you great control but gets a bit fiddly and tiresome so I wrote a script to help with this. In the interest of full disclosure, I’m selling this After Effects plugin on aescripts, but it is definitely how I would approach this kind of write-on effect.
https://aescripts.com/quickdraw
Check the Comments section on the aescripts page as there have been a few updates since the first release. One downside to using the Paint Effect is that it doesn’t play well with layers that have the Constantly Rasterise asterisk turned on, but there are work arounds for that.
Laurence Yates
Motion Graphics Artist and Illustrator
Creator of QuickDraw – https://aescripts.com/quickdraw/
https://www.notbyhalf.com/ -
David Tunnell
February 24, 2014 at 12:35 amLaurence, I aw that script Awesome isn’t it. By precomposing text layer it works fine
David Tunnell
