Activity › Forums › Adobe After Effects › Writing on steamy glass/mirror
Posted by Seth Brown on September 24, 2016 at 12:34 pmHi how i can make steamy mirror and write text on it?
Tudor “ted” jelescu replied 9 years, 12 months ago 3 Members · 2 Replies -
Kalleheikki Kannisto
September 24, 2016 at 5:32 pmMake the background you see through the glass blurred and slightly whitish then mask off the areas where you write things on (or do a write-on effect for a mask) and show a clear version of the background through there. Plus possibly add some stray dots here and there with glass effect.
Senior Graphic Designer -
Tudor “ted” jelescu
September 26, 2016 at 8:55 amAlso adding some real water drops sliding down from the area where the letters are revealed will add to the realism of the shot.
Something like this:
https://www.youtube.com/watch?v=ksaovTzrvGg
Tudor \”Ted\” Jelescu
Senior VFX ArtistSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
