Activity › Forums › Adobe Photoshop › Writing in the sand
Writing in the sand
Posted by Michael Morgan on April 10, 2006 at 9:13 pmDoes anyone know how I how to make text look as though it was written in Sand using Photoshop or After Effects
Mike Gondek replied 20 years, 5 months ago 2 Members · 1 Reply -
1 Reply
Mike Gondek
April 11, 2006 at 1:59 pmDeboss the sand
Choose a simple fonts such as tekton bold, set you message.
Add a bevel and emboss layer effect. Chaneg the shadow blend mode to color burn, and the highlight mode to soft light.
Change the fill opactiy to 0% leaving the effect opacity at 100%.(these next 2 steps are optional for an even more convincing look if you have the time, and are looking for a quality high res image)
Displace the sand
Save a flattened .psd file of just the bevel layer on a white background. Run a filter >>distort>> displace and use the .spd file you made.Raise the sand higher on the outer edges
Make a layer over the entire image of a repeating pattern of the sand all disturbed.
Add a layer mask that hides all.
Paint on the layer mask over the edges of the type with a rough brush to reveal the higher up sand layer on the outer edges of the type.
